My turn signal stop working. It will work when I spray electrical cleaner in there, and when I turn the signal on (but not let it go all the way down). I cant figure out how to get to the contacts to clean them... or do u think there is another problem? Please help
Re: Turn Signal
My turn signals wouldn't work unless the steering wheel was in the center position (tilt wheel) I found out that the wire for the signal indicator had pulled out of the harness block under the column cover. Once I pushed the wire back in it worked like it should.
Re: Turn Signal
What year? 90s models are notorious for multifunction switch failures. They can show up as hazard or turn signal issues.
IS IT FIXXED YET?!
