Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 09-25-2005, 12:26 PM
noeldawn noeldawn is offline
97 Towncar will not start
My 1997 towncar will crank but not start. I had the same problem last week. AAA came and said the emergency fuel pump switch may have been turned off. Tried the switch this time but it was already down. Twice last week when I filled my tank, I had fuel splash out when the tank got full. Not sure if this is related.
Old 09-26-2005, 01:24 PM
Towncar's Avatar
Towncar Towncar is offline
Re: 97 Towncar will not start
Check the power relays in the main power distribution box under the hood. There's 3 or 4 relays in that box where at least 2 of then can cause intermittant starting / running problems until they eventually fail 100%.
From memory, their all the same type and connector, so you can move them around for diagnosis purposes.
They run about $6.00 + at all the AP stores. Carry some spares in case you get a problem on a lonely, dark, deserted highway...
Post back with your findings please. There seems to be a few of these threads running right now.
-Steven
1996 Town Car, Cartier
Old 09-29-2005, 03:00 AM
ltdltc ltdltc is offline
Take a look at the engine Cam sensor.
