Old 09-25-2005, 09:32 AM
ga_relicman ga_relicman is offline
2000Blazer Won't Crank
I've got a 200 S-10 Chevy Blazer. I"M not getting any power to the ignition switch.Sometimesit will work fine .Cranks right up.When it wont't work the dash lights won't even come on.Could it be the park netural switch bad?The actual ignition switch works fine when you get power to it.
Old 09-25-2005, 09:37 AM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Re: 2000Blazer Won't Crank
First thing to check are your battery connections.
If the Neutral safety switch were the problem, you should still have dash lights.
Your symtoms sound like a bad ignition switch/harness, but I only know of this being the problem on '97s.
Old 09-25-2005, 01:49 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Yip, clean and recheck your battery connections.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 09-25-2005, 06:14 PM
Re: Re: 2000Blazer Won't Crank
Thanks for the reply I've already checked the battery.The other day it wouldn't crank and I had left the key in the ignition. I was jacking it up so I could get under it to look at something and all of a sudden I heard the key left in ignition alarm going off. Me jacking it up made something make contact. It cranked right up when I tried it. I'm ready to strike a match to it before this it was the fuel pump $400 and I put it in. Before that front wheel brg$300 and I did the work. I've already priced getting the the ignition switch changed $500 I'll trade the sob first if it will crank to get it there.
Old 09-25-2005, 07:02 PM
BlazerLT's Avatar
AF -Advisor
You have to check all the connections and cables.
The cable is said to sometime break off inside near the battery connection.
Old 09-26-2005, 01:26 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
See my 2 threads on Positive Battery Harness. Like BlazerLT says, check the entire cable/harness. My positive cable corroded through and broke off inside the plastic sheath that covers the terminal.
To see my threads, click on my name and then click on "FIND ALL THREADS STARTED BY THIS USER"
