Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 09-24-2005, 11:43 PM
trout250 trout250 is offline
95 tahoe power steering pump install
having to install a new pump on the wifes 95, got it off ok but the shaft was broken and front pulley just slipped off, can anybody out there give me any clues as to how to get the new one back on. pump is on the right side looking at engine under the alternator. thanks.
Old 09-25-2005, 06:44 PM
power steering pump
well I figured it out myself. Incase somebody else runs into this problem, you just pull all the brackets off with the pump, you will have to use an offset 9/16 ths box end wrench to remove the top bolt out of the aluminum bracket and use the same wrench to put it back, install the pump onto the brackets wilth it on a work bench. leave the two nuts on the rear studs loose until you get the bracket back on the exhaust manifold, downhill fromm there.
