Old 09-24-2005, 11:28 PM
Hotshot8792 Hotshot8792 is offline
anyone interested in a TT conversion kit?
A buddy of mine has a nearly complete kit for anyone on here looking to TT their N/A. He bought a donor car in hopes of TTing his car, but has decided to sell it so he can get his car painted. He doesn't know much about the TT world, so I can confirm the parts that he has. It has everything you need except for some random nuts and bolts, gaskets, fuel management, gauges, and boost controller. If anyone is interested, let me know and I will relay the message to him. He's asking $1100 for all of it.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 09-25-2005, 11:30 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: anyone interested in a TT conversion kit?
i'm interested. since your in Alabama (i'm assuming your friend who has the TT is from there to) and i'm in TX...is the TT driveable?
or is the car a parts car?
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 09-27-2005, 12:15 AM
Re: Re: anyone interested in a TT conversion kit?
well, it was just the tt conversion that he was going to sell. The car is just a parts car for us that we had bought to part out because it had a blown short block. I think someone is interested in the tt conversion right now. But yes, my friend with the parts car lives a few streets over from me, we more or less went in together on the car, he bought it and wanted me to help him part it out.
Old 09-27-2005, 02:46 AM
Linebckr49's Avatar
sounds like the best route for the TT conversion--> buy a parts/donor TT car that has a blown engine, so you can get it for cheap. I think i'll do that whenever i get the cash for it.
i was just curious. go ahead and let that other person who's interested have at it. good luck selling it!
93 3000GT base
Old 09-27-2005, 06:40 PM
k, well if it falls through, i'll be sure to post back up here for anyone still wanting to grab it
Old 10-03-2005, 09:09 PM
its still up for anyone who wants the kit
Old 10-03-2005, 09:53 PM
compaqpunch compaqpunch is offline
I wish i didn't reck my car and have to spend all my money on it to fix it back up or i would deffinatly buy it.
Old 10-03-2005, 10:41 PM
Linebckr49's Avatar
hey Compaq....you and me are in the same boat! i wrecked my car back in May and all the money i earned this summer went to repairing it. such is life. i posted some cool pics of the damage in the Pics of Your Ride sticky thread. i need to take more and update it now that's she's all fixed.
93 3000GT base
Old 10-04-2005, 11:49 AM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Hotshot you would know...how much boost could I run on the SL block safely and still see 13's? And is there any fabrication needed to put it in?
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 10-08-2005, 03:52 PM
sorry i haven't responded sooner, i haven't been on here in a couple of days.
Well, as far as boost goes, on the SL motor, 6 PSI has low as 13.5 in the 1/4 mile, most people can tend to run around 10 PSI without any kind of alky, and then 13 PSI with alky. As far as modification needed, you will need to cut some sheet metal out behind the driver's side headlight where the driver's side intercooler goes through, and you will need to modify the rear intercooler pipe to go around the N/A plenum, unless you get a tt plenum from somewhere. I would also recommend, if you have a manual, to install at least an LSD insert and and upgraded clutch. Other than that, all you'd need to do is buy some nuts, bolts, gaskets, and a couple of oil and coolant lines for the turbos, and electronics that are needed.
Note: If you want to e-mail my friend, his e-mail address is [email protected] and his 3SI board name is Gator91ES
