question on a 327 small block
ok,if i have a 327 bored 60 over,could anybody tell me how much horse power it is capble of pushing out,thanks jesse
Re: question on a 327 small block
The only way to really tell is to run it on a dyno or racetrack, but if you told us more specifics about your engine an educated estimate could be made.
Welcome aboard.
Mark's Garage est. 1983 |
you have to know the cam specs, head specs, intake and carb specs and compression for starters. Somewhere I have a PC program that will tell you with all the specs punched in to it. Will even tell you what your quarter mile times would be if you enter vehicle weight and exhaust specs.and gear ratios, tire sizes and such. I'll see if I can find it and if I can get it to you.
If you have bucks to spend you can have it dyno tested.
Check out my 1966 Chevelle here: ![]() http://hometown.aol.com/abrucelee1/i...ml1badrat.html |
most engines today can be built to exceed 1hp per cu inch.
