Old 09-24-2005, 08:37 PM
Andee_G's Avatar
Andee_G Andee_G is offline
CF problem...
i used to photochop a ton, and did carbon fiber stuff frequently. I relooked up the tutorial on photoshopjunkie and photoshopchop and made the pattern. then i added it as a pattern fill layer; worked fine. but when i try to distort it, it says "could not transform because the initial bounding rectangle is empty" WTF? i tried making the pattern again, and tried pasting it in again, but to no avail. When i did it before, it worked perfectly the first time. could someone plz help me?
P.S. i'm using PS elements
Old 10-04-2005, 06:58 PM
Andee_G's Avatar
Re: CF problem...
reinstalled photosop, same problem
Old 10-04-2005, 08:03 PM
Amea's Avatar
Amea Amea is offline
Send a message via AIM to Amea
You have to rasterize the layer. Right click on the layer and choose Rasterize. Lemme know if it works!
Old 10-05-2005, 01:13 AM
Andee_G's Avatar
Re: CF problem...
couldn't find 'rasterize' with photoshop elements, but i simplified the layer which seems to have solved my problem.
thanks for the inspiration
Old 10-05-2005, 02:26 AM
ghettofamily ghettofamily is offline
Re: CF problem...
Maybe i didnt understand your question, but did you flatten your image, before you tried to distort your new layer?
