Old 09-24-2005, 08:02 PM
jshirley jshirley is offline
digital dashboard-93 s-10 blazer
I have a 93 S-10 Blazer 4X4 with electonic instrument dash. The only thing working on it is the speedo, trip meter, and seat belt light, plus the orange and red bars are visible on the lower right.
All fuses are good, but noticed a 3 amp fuse for the ECm not in. i have the plug on he underside of the dash, how to check if fuse is necessary. Is there a cheap fix for the dash?
Old 09-24-2005, 08:04 PM
Re: digital dashboard-93 s-10 blazer
I have a 93 S-10 Blazer with electronic instrument panel, only the speedo, tripmeter, orange and red bars on the lower right and seat belt and service engine soon warning lights work, both of the latter go off after strrting up; all fuses work, how to fix cheaply?
Old 09-28-2005, 11:22 PM
FishinS10 FishinS10 is offline
Do a search. You'll find that you have a common problem. The circuit board in your electronic dash probably has a break in it. If you run a google search you will find a few places that will take your dash and do the repairs. Expect to spend around 300.00.If you take it to a dealer, they will need it for about 2 days and charge 500-600.
Been there and done that.
Good luck..
Old 12-09-2005, 05:11 PM
dhodson2004's Avatar
dhodson2004 dhodson2004 is offline
Send a message via AIM to dhodson2004 Send a message via Yahoo to dhodson2004
My 91 S-10 Blazer has gone through 3 digital clusters. The circuit board goes bad, common problem. Very easy to change, just need about $100.00 for a used cluster at a junk yard.
Old 12-09-2005, 06:00 PM
04 blazer 04 blazer is offline
Check out this Ebay seller. He has very good feedback on his repaired clusters.
http://cgi.ebay.com/ebaymotors/1989-...QQcmdZViewItem
Old 12-09-2005, 08:30 PM
I have browsed the eBay stores in the past for this item also. If you take the eBay route, just make sure that you do send the seller your junk circuit board.
