Go Back   Automotive Forums Car Chat > Honda > Odyssey
Old 09-24-2005, 07:16 PM
Maxumis Maxumis is offline
Where is ECU on 2003 Odyssey
Where is the ECU on the 2003 Odyssey and how do I check it? Where can I find a ECU decoder?
Old 09-25-2005, 08:32 PM
lorunner lorunner is offline
Re: Where is ECU on 2003 Odyssey
the ECU is under the center of the dash on the floor. Peak in by the gas pedal and you should see it. Why do you need to check it? And what do you mean by decoder?
Stop asking me about radio codes I cant get them anymore!!!
Old 09-26-2005, 08:02 PM
Question Re: Re: Where is ECU on 2003 Odyssey
[quote=lorunner]the ECU is under the center of the dash on the floor. Peak in by the gas pedal and you should see it. Why do you need to check it? And what do you mean by decoder?
In my 99 Nissan Maxima you can tell what is wrong with the car by turning a little screw on the ECU and a light blinks on the dash...for example 9 fast blinks and one slow blink of the light means the O2 sensor is bad. How is the Honda Odyssey set up to determine what is wrong with the vehicle?
