Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 09-24-2005, 06:30 PM
casanoah casanoah is offline
blower motor module location?
Hi all. Working on a 93 bonne. Blower motor (heater/AC) stopped working entirely.
Checked for power at the motor with test light, nothing.
I assume the motor itself is still ok since there is simply no power
getting to it anymore, could jump another wire to it to make sure but
let's assume it's good. Is it then, probably a module?
Under a long cover on the fire wall there are many modules with
little or no identification. I read on some of these posts the blower
motor module and resistor are located almost right next to the motor,
but I think it was for a different year bonneville since I see nothing
of the like. ANY suggestions would be greatly appreciated.
Old 09-24-2005, 06:40 PM
randman1's Avatar
randman1 randman1 is offline
Re: blower motor module location?
What you are seeing under the cover are relays and Maxifuses. The BCM in located a little lower under the right hand (passenger's side) fuses/relays. You can follow the wire loom from the blower motor directly to the BCM.
Old 09-24-2005, 06:47 PM
Thank you for such a fast reply, I will check it out
now that I have some direction.
Very much appreciated.
