Go Back   Automotive Forums Car Chat > Honda > How-To's and Walk-Through's
How-To's and Walk-Through's Here's where we show you how it's done!
Old 09-24-2005, 04:31 PM
bdgpick bdgpick is offline
Post 94 accord rear rotor replacement
How hard is it to replace the rear rotors on a 94 accord?
Old 09-26-2005, 11:06 PM
BullShifter's Avatar
Re: 94 accord rear rotor replacement
Simple
Pull off the caliper & caliper bracket
Remove 2 phillips screws holding rotor on if they haven't been busted off already.
The hardest part is getting the screws out without using the correct tool. You should us an Impact driver, its basically a screwdriver bit you hit with a hammer. Most auto parts stores can rent you one or you may buy one.
here is one for ref. - http://www.sears.com/sr/javasr/produ...&vertical=TOOL
Old 09-29-2005, 07:58 PM
Bullshifter thanks for the advice on the impact driver, couldn't have done the job without it!!!!
Thanks again
Old 09-29-2005, 10:58 PM
Re: Re: 94 accord rear rotor replacement
that's what I'm here for.
