Re: warning chime location
My manual says that connector C2020 is located behind the lower center of the instrument panel, on the warning chime module. The connector will be a flat 10-terminal connector with a 9 wires. Wire 1 with be dark green with a light green stripe, wire 2 will be red with a yellow stripe, wire 3 will be white with a pink stripe, wire 4 will be red with a pink stripe, wire 5 will be white with a red stripe or brown (base taurus/sable). Wire 6 will be black with a pink stripe, wire 7 will be tan with a yellow stripe, wire 8 is not used. Wire 9 will be brown with a light blue stripe, and wire 10 will be black.
