Old 09-24-2005, 03:46 PM
gtboiii11 gtboiii11 is offline
Send a message via AIM to gtboiii11
camaro power windows
need a smart wiring guy or mechanic to tell me what i have to do exactly to convert manual windows to power windows, i know it is possible to do but have no clue where to start
Old 09-24-2005, 07:52 PM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
well, what you're gonna have to do is wire in a hot wire that comes one when the accessories are turned on (or splice into a wire that goes hot w/ accessories) wire that into a switch, ground that switch... have that switch connected to the window motor. the switch has to be the kind of switch that reverses the power and ground wires to the motor...
idk if you know how a power window motor works but it has two prongs on it, and when the power and ground wires are arranged one way the motor goes up, and when the power and ground are switched, it goes down... i can't tell you specifics, but that's the concept of what needs to be done...
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
