Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 09-24-2005, 02:50 PM
one_lost_punk one_lost_punk is offline
surging
a while back i bought a generic ebay CAI for my 92 lude si, i noticed that there is some vacum line that connects to the stock intake, i wasnt sure what it was for and the car seemed to run fine. so i just left it disconnected. Lately though my car has been surging and i am wondering if it might be because of that vacum line. Today im changing the o2 sensor in case its that and getting a tighter clamp for the oil breather hose, but i just want to know if it might be that vacum line.
Old 09-24-2005, 11:09 PM
NexTnmE NexTnmE is offline
Send a message via AIM to NexTnmE
yeah...that hose needs to be hooked up : ) what i did is drill a small hole in the rubber o-ring that bolts the intake to the throttle body and just put the hose in it about 1/4 of an inch...put some sealant around it to make sure it wont pull out...and it works great...no more surging.
Old 09-25-2005, 09:44 AM
ShoofIsLudin ShoofIsLudin is offline
I did the same thing when i first got my prelude...it makes it easier if u pull the metal nipple off the stock intake with a pair of pliers, then just poke a small hole in the rubber coupling connecting the intake to the TB, then squeeze the metal nipple thru your hole, and connect the vacuum hose...that should do it.
Old 09-25-2005, 01:01 PM
well ill try hooking up the vacum line to that, i just put some electrical tape over it to see what it would do, but it didnt fix it. I was reading something about the holes at 7 and 9 on the tb and plugging them to see if the surging stops... well to find the problem.
Old 09-25-2005, 06:38 PM
yeah i tried just plugging the hose with a stopper...but it needs to be in the intake...it needs just a lil bit of vacuum pressure and it seems to work...
