Old 09-24-2005, 02:32 PM
farm5232 farm5232 is offline
2001 misfire
I have a 2001 chevy 1500 and the code reader tells me the 5th cylinder is misfireing and that the other code it tells me is knock sensor 2 low circuit. My pickup idols rough and low on power. Can anyone help me.
Old 09-24-2005, 03:05 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: 2001 misfire
Well the misfire could be internal engine, fuel or ignition related...you will need to do a little testing to find out which one..I would say start with the ignition system..you could swap plugs, wires and coils with another cylinder and see if the misfire moves.
As far as the knock sensor, probally a bad sensor or connection..I believe there was a TSB about those.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 09-24-2005, 03:15 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Re: 2001 misfire
And they put the damn knock sensors UNDER the intake manifold
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 09-25-2005, 09:58 AM
Re: Re: 2001 misfire
thanks I will try testing like that and replacing the sensor.
Old 09-28-2005, 08:08 PM
how do i swap the coil , i already tried the spark plug and wire and the misfire did not move. can you tell me where the coil is and how to swap it. thanks
Old 09-28-2005, 09:27 PM
Re: 2001 misfire
Is it a v6 or a v8? If it's a v8, the coils are on top of the valve covers... the little "black boxes" the plug wires plug into. If it's a v6, the coil is on the distributor cap. If it's a v6, your point for that cylinder may be bad, and a new cap may be in order.
Old 09-29-2005, 03:27 PM
fire24resque's Avatar
fire24resque fire24resque is offline
I had the same problem about a year ago and found what the issue was in a few minutes. I pulled one of the wires off a plug and found that the metal spring inside the little boot detached itself from the plug wire causing a miss and occasionally touching and making the motor run very rough.
2001 Silverado 4x4 - 4.8 V8 - Hankook Dynapro ATm RF10s, 265/75/16
K&N FIPK - Flowmaster 50 Series 3.5" Duals
4-Headlight Conversion Kit - Billet Grille
90 Watt Nova Strobe Pack
2.5% Limo Tint -
Check Out Pictures and More Here
http://www.cardomain.com/ride/2131569/1
Old 09-30-2005, 06:54 PM
i tried switching the coils and the codes cleared on their own the pickup still runs rough. after i drove it for a while the s.e.s. light came back on but my cheap code reader will not read the code or codes. Should i just take it to someone with a real code reader? Thanks for all your help.
Old 09-30-2005, 07:02 PM
misfitt006 misfitt006 is offline
Send a message via Yahoo to misfitt006
Re: 2001 misfire
Take it to Autozone or Kragen or other autoparts strore, they should have a code reader that they can run for free to tell you the fault codes.
