Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 09-24-2005, 01:58 PM
ale_k300 ale_k300 is offline
Ignorant Question, replacing Sparks Plugs
Car: Mitsubishi Eclipse Spyder 1997 GS
I really feel stupid asking this, but i was trying to replace the spark plugs in my car, and i can't seem to be able to remove the wires... can someone gimme the steps i need to follow?
Thanks.
Alex
PS: Also i'm thinking on selling my car in the next month and i need to know how much i can ask for it...
Is Mitsubishi Eclipse Spyder 1997 GS , with 105k miles on it, from the outside it looks just fine , but this 3 things need to be done:
Replace Top ( around $700 ) , Change Timing Belt ( around $400 ? )
Old 09-24-2005, 03:31 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Just put a good grip on the base of the wire above the plug, and pull hard. Should pop right off.
To figure out your car's value, try www.kbb.com
Depending on your location and any extra luxuries on the car not listed, your car should be in a range of +/- $1,000. Start there to get a rough estimate of what it's worth, and then start to subtract things that are wrong with it, add a little value of any extras you put into it, etc.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
