Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-24-2005, 12:48 PM
JDusen4211 JDusen4211 is offline
Send a message via AIM to JDusen4211
93 mustang suspention problem
how much trouble is it to replace the rear coil springs? i shouldn't need a spring compressor right?
i know it has been hitting the bump stops when i hit bumps at high rates of speed, and now it seems to do it with little bumps at low speeds. although there is 3 inches or so in between the center bump stop and the diff.
recently i have noticed a slight rocking motion (back and forth) that occurs very rarely between 40 and 50 mph. it even occurs when it is in neutral at those speeds. could this be caused by the wore out springs too? or should i replace something else while i am replacing the springs?
Old 09-24-2005, 06:40 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: 93 mustang suspention problem
Mustangs are not known for their long suspension travel, so bottoming out is fairly common if you have a heavy load in the car. It is unusual to do so if its just the driver in the car.
Replacing '79 and up rear springs is easy on a live axle car.
Raise the rear of the car and support it on the chassis with jackstands. Place a trolly jack under the diff , and lift the axle about an inch from full droop.
Remove the rear shocks at the lower mount only, and the rear wheels. You may have to loosen the rear sway bar, if equipped.
Place a jack under the lower control arm and remove the pivot bolt and nut, one side only. Lower the jacks a bit (be careful not to stretch the brake flex line), and the spring should come out.
As for the side to side movement......inspect the upper control arm bushings for wear and looseness. Since you are already doing this work, consider removing all the control arms and replacing all the bushings.
