Old 09-24-2005, 12:38 PM
78burbsixsiximpala 78burbsixsiximpala is offline
Crazy Fuel Pumps
well im new to the 78 style surban. i just got one. now, it ran fine and then it stopped getting fuel to the carb. so i go to check out the fuel pump well turned out i have two. one electric holley and then the mechanical one by the engine. now i dont know if that is normal or odd? anybody else have this? i replace the fuel filters. NO luck. so i am almost 100% sure its the fuel pump . but which one? do i need both? should i replacec one see if it works then go ahead and get the other one? shit. anybody that has any info would be much apriciated
Old 09-24-2005, 04:45 PM
broughy84's Avatar
broughy84 broughy84 is offline
Re: Crazy Fuel Pumps
I would say that the electric holley is aftermarket
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 09-25-2005, 12:09 PM
jveik jveik is offline
yeah someone probably put the holley in and it just bypasses the one on the block. ive heard of people doing that when the one on the block goes bad
Old 09-26-2005, 12:02 AM
blue4X4 blue4X4 is offline
just my opinion, but electric pumps are junk. Ive replaced 2 in 6 months inside my gas tank. I would rathur have the mechanical that runs off the crank. Too many things to go wrong on the electric pumps compared to the mechanical. Plus, its a cinch to replace a mechanical. I swear the whole reason they made the electric pumps(especially the ones in the tank) is so you have to take it to a mechanic. With a mechanical pump you know its bad when your not getting gas, electric pumps it could be relays, sending units or about 10 other things.
Being your electric is external from the tank it wouldnt be so bad to replace it if you wanted to.
Check out my 1966 Chevelle here:
http://hometown.aol.com/abrucelee1/i...ml1badrat.html
Old 09-26-2005, 05:03 AM
Tall Tall is offline
You cant get high enough fuel pressure with a mechanicle pump for fuel injection....
