Go Back   Automotive Forums Car Chat > Buick > Regal
Old 09-23-2005, 10:23 PM
jpb551 jpb551 is offline
1994 buick regal brake light problem
Brake lights on passenger side don't work, bulbs good, wires up to dash good(at least as far as I can trace them without tearing dash apart), need wiring diagram and/or possible cause.
Old 09-28-2005, 10:21 PM
buckingham buckingham is offline
Re: 1994 buick regal brake light problem
I had the same problem. Your turn signal on that side I expect don't work either. I had to replace the turn sign mechanism found on the steering column. Fiddle with that turn signal switch, by pulling it toward or away from you and you should get the light to work briefly. Hope it helped.
Old 10-04-2005, 12:33 AM
drpepper13 drpepper13 is offline
this might help you if you need to change the turn signal Switch.(wich is prolly ur problem)
http://www.likeabigdog.com/column/94upsignal.htm
This is my problem if anyone can help!
http://www.automotiveforums.com/vbul...d.php?t=455540
