Old 09-23-2005, 08:28 PM
deltableh deltableh is offline
Send a message via ICQ to deltableh Send a message via AIM to deltableh Send a message via MSN to deltableh Send a message via Yahoo to deltableh Send a message via Skype™ to deltableh
Resin flash?
I just got my MSM 360CS Transkit, and I like everything in it, and how it looks. However, there are large... chunks, of resin on the wheels, the bottoms of the seats, the door panels, and much more. I should be getting rid of that, right? Or is that something hideously important that I should be keeping?
Old 09-23-2005, 08:33 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Go ahead and hack it off. The attached blocks are the resin equivalent of sprues- resin is poured into molds by way of ports in the mold, and it hardens in the ports, leaving extra shapes stuck onto the parts. Carefully remove what shouldn't be there.
PHOTOBUCKET SUCKS
Old 09-23-2005, 08:39 PM
Re: Resin flash?
That's what I thought. Yay! Whittling time with my pocket knife!
/cue Dueling Banjos
Old 09-23-2005, 09:30 PM
Vric's Avatar
Vric Vric is offline
Re: Resin flash?
WORK SLOWLY.
Error are very hard to correct on resin. So when you clean the small part, be patient. this is a very long step.
Old 09-24-2005, 01:22 AM
sjelic's Avatar
sjelic sjelic is offline
Re: Re: Resin flash?
Originally Posted by Vric
WORK SLOWLY.
Eric is right, resin is like glass, take some small saw rather then knife.
Sasa Jelic
SCALEMAKERS
Old 09-24-2005, 11:39 AM
Vric's Avatar
Re: Re: Re: Resin flash?
and wear a mask (even a paper mask) if you sand resin.
Old 09-24-2005, 12:30 PM
mickbench's Avatar
mickbench mickbench is offline
I got some resin parts once, and I did not follow the correct procedure for handling them, and the parts really just ended up in the bin. I think resin is VERY hard to work with, and I've not touched it since.
Good luck, be careful.
Old 09-24-2005, 01:49 PM
Re: Resin flash?
Well, I've got most of the flash whittled off. I used the short blade on my pocket knife for more control, and took it off one thin layer at a time, like you would with wood. In the end, no nicks at all, nor are there any gouges bigger than what the primer and black paint won't take care off. I'm actually anticipating getting home with this kit (I recieved the transkit at college, the model itself is at home) because the model is a Spyder, and it looks like I might be able to use the resin rear hatch, only in a horizontal, rather than angled, application.
