I have a problem where may brake lights don't work. Everything else works.(Back-up, turn signals and tail lights.) I checked the bulbs they all look good. I also check all the fuses, look good. The cab brake light works. Followed the wires the whole length of the harness from front to rear, found no problems.
Re: 98 S-10 Break lights don't work
I've seen bulbs that look good, that aren't. So this is where I would start
We should all carry at least 1 spare bulb anyways, so this won't cost you extra. |
some cases a bad nutrul safty switch will cause this
where do I find the neutral safety switch?
start at the base of the break peddle, and work you way up untill you find it
I would start looking at the brake light switch itself since everything else works... As to where the safety neutral switch is, it's actually on the side of the transmission, unlikely culprit in my opinion. Again though, check the brake switch at the top of the pedal.
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal |
^excuse me, rlith, you are correct, and i was thinking correctly, but saying the wrong switch... break switch, he would of found it, but had the wrong name... sorry
The cab brake light works, is there two seperate switches? I would think that, if the brake light switch was bad, the cab light wouldn't work either. I haven't checked the switch yet, I crawl under, where the brake pedel is and I didn't see a switch. Looks to be a pretty tight area to work. I hope someone could put me in the right direction.
Thanks, Mike |
When i first got my S-10 I was having the same problem. I took it to my local mechanic and he couldnt find the problem either. So he had it sent to the local dealership and they had it for a few days. The problem was a relay or a circuit board next to the head lamp. I live in AZ so the summer heat beating down on my black truck just fried it.
I just had the exact same problem and it turns out all you gotta do is change the relay it sounds weird but it worked i repaced my brake like switch first and nothing happend i changed the relay .......Problem solved
thread is now over 2 years old. please refrain from posting in old threads
2000 Chevy Blazer ZR2 Performance Mods: Numerous Suspension Mods: Some, but not enough Exterior Mods: Just Right 1987 Buick Turbo T Dark Red Low 11 sec sleeper ![]() .030 4.1 block, PT6262E, & other odds and ends.... My Cardomain |
