Old 09-23-2005, 05:10 PM
jamroll jamroll is offline
Blinking D4... help with code please
Out of the blue... D4 blinking... tach working... speedo not working... odometer not working... cruise not working... tranny questionable performance...95 accord...??? mileage.
Followed instructions in "FAQ Got a blinking light" above... reset ecu/... drove around over 30 for a few minutes... jumped two pins in service plug with paper clip...
turn on ignition... check engine comes on, stays on, solid light... SRS comes on, blinks continuously, no discernable pattern, just continuous blinking at what appears to be a constant rate... D4 blinks 4 counts off three counts, blinks to a 4 count, off for a 3 three count, very consistent...
Any ideas? Help...
Old 09-24-2005, 03:12 PM
gitter44 gitter44 is offline
Speed sensor...
Old 09-25-2005, 08:38 PM
lorunner lorunner is offline
Re: Blinking D4... help with code please
43 is an O2 sensor code. Is this a 4cyl or a V6 ?
The first set of blinks should be slow then a break and the second set should be faster. If they are both the same than you may have a code 4 and a code 3. so check again and see if they are both flashing the same
Stop asking me about radio codes I cant get them anymore!!!
