Old 09-23-2005, 02:14 PM
INNES's Avatar
INNES INNES is offline
Question rocker arm ratio
i just picked up from the boneyard GT-40 heads off a 97'explorer (not GTP). It looks like the rocker arms on it are 1.5 cause i see the #5 on them.I plan on replaceing them anyway. the question i have is can i put 1.7 on it. i know the 93/94 cobra had these heads w/1.7 rockers.Are the heads completely simaler or are they alittle different and i have to machine them a little
P.S my car is a 88'thunderbird w/a mass air 5.0 motor auto
Old 09-23-2005, 04:00 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: rocker arm ratio
The heads will be fine with 1.7 rockers. Its the pistons and valves I'd worry about. Gotta makes sure you have the proper piston to valve clearance.
1969 Cougar
357w & TKO - 475hp
Old 09-29-2005, 08:07 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
With 1.7 rockers you should be fine, you not increasing the valve lift a ton by going with those. If you have a performance can and added 1.7's then I'd be sure to clay the pistons.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 09-29-2005, 03:04 PM
351wStang's Avatar
What sre the stats on a stock 5.0 HO cam?
1969 Cougar
357w & TKO - 475hp
Old 09-29-2005, 05:34 PM
HiFlow5 0's Avatar
Stanger
Re: Re: rocker arm ratio
Cam or rockers? The cam really depends on the year, since there were lots of minor profile changes thoughout the years. But it's valve lift is right around .416/.444, intake/exhaust. Stock rockers were designed to be a 1.6 ratio.
-2013 Ford Flex
-1999 Ford F150
Old 09-29-2005, 09:50 PM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
Checking is never a bad thing, but you should be fine. Be sure and put a good set of springs on, the Explorer springs usually weren't very strong (mine had uneven pressures at 104K, a buddy's had the same at less miles....
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
