Old 09-23-2005, 12:25 PM
93mx6lsv6 93mx6lsv6 is offline
LS Autoride, anyone know what this is?
My truck is an LS model. But on the passenger side, the emblem on the rear door says LS and Autoride underneath it. Anyone have a clue what this means?
2005 Ford Ranger XLT 4x4 4.0 5spd
-3 in. body lift
-15x8 Mickey Thompson Classic II's
-32x11.50 BFG All Terrains
Old 09-23-2005, 12:38 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Re: LS Autoride, anyone know what this is?
Must be a 4wd thing
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 09-23-2005, 01:37 PM
Snowbrdr1122 Snowbrdr1122 is offline
Send a message via AIM to Snowbrdr1122
Autoride was only availible on Tahoes/Suburbans. Its likley your truck is misbadged
2005 Chevy Silverado 1500 Crew Cab Z-71
-Access Roll Top Tonneau
-Cranked T-bars
-285 BFG All Terrains
Next up, 10" lift, rims/tires, and exhaust
Old 09-23-2005, 03:09 PM
Ape0r Ape0r is offline
Send a message via AIM to Ape0r
As mentioned above, Autoride is either an automatic load leveling system (1500) or an automatic damping adjustment system (2500). Don't think its available on pickups, just the SUVs.
'04 Silverado 1500 4x4 5.3L 3.73 G80
Old 09-23-2005, 03:11 PM
jethro_3's Avatar
jethro_3 jethro_3 is offline
Autoride is an electronic controlled shock. It would let it ride hard or soft depending on the switch setting. The computer would then let the valves in the shock open more or less letting the fluid dump faster or slower. I will look in the manual for more but that is the down and dirty....
"The Sleeper" '05 6.0L VHO
Cam in and
Low 14's happening at the track
Check out my Ride
Old 09-23-2005, 03:35 PM
I wish I knew why the badge was on there then. When I bought my truck back in May, it originally belonged to an older man, everything on it was stock. Not quite sure why that would have been put on there by and older man. Beats me. I guess it's time to do some research.
-3 in. body lift
Old 09-23-2005, 03:39 PM
This qouted from this website: http://www.truckworld.com/Truck-Test...y2k-chevy.html
Overall ride, handling and turning diameter have been improved. Significant trailer towing enhancements include Premium Smooth Ride Suspension and Autoride "Real Time Damping" Suspension. The former (optional on K1500 Series) features self-leveling rear shocks that use energy from normal suspension ride motion to adjust and maintain level vehicle trim heights and help improve handling. The latter is a fully-automatic system which utilizes information from wheel height, steering and other sensors to continuously vary shock damping while driving. Electronic sensors control a compressor pump that keeps the rear of the vehicle level with the front. Suburban (and Silverado) also offer pre-wired trailer connections, pre-wired brake controller, Tow/Haul mode on the transmission to adjust shift points and dynamic rear proportioning that helps maximize rear brakes while trailering.
-3 in. body lift
Old 09-23-2005, 07:09 PM
I guess you learn somthing new, I worked in a Chevy dealer for 3 years and never saw a Silverado with Autoride... Must have been special ordered
-Cranked T-bars
Old 09-23-2005, 08:16 PM
jethro_3's Avatar
Are you saying they might have added the badges or does your truck really have the wires and hoses to the shocks as the badge implies????
Does anyone know the RPO for the Autoride?
Old 09-23-2005, 08:24 PM
I don't know I haven't looked at the shocks or anything. What should I look for? I doubt VERY seriously that the old man put that badge on there for the heck of it. But who knows? Does anyone have a Car Fax account?
-3 in. body lift
Old 09-23-2005, 08:47 PM
jethro_3's Avatar
Look in your glove box at the RPO codes and see if you have this... ZX3 Adjustable Electronic (Selectable) Suspension.
Cam in and
Check out my Ride
Old 09-23-2005, 08:52 PM
It doesn't. But one thing I just noticed was on the badge on the driver side there is a small tiny bit of paint on that badge. So I have come to the conclusion that the truck has been painted. I really want to get a CarFax now. It worries me.
-3 in. body lift
Old 09-23-2005, 10:28 PM
jethro_3's Avatar
Go to your dealer and have the service person print out the RPO/Description pages for all the options that were put on your truck.
Are you really prepared for what was done to your truck prior to you??? If you go to a fly by night shop they are not required to report all repairs to CAR FAX.
Old 09-23-2005, 10:39 PM
I purchased my truck from a LARGE Chevrolet dealership here in North Carolina. It's no little dealer sitting at a stop light corner. Should it have been reported to me?
-3 in. body lift
Old 09-23-2005, 10:48 PM
jethro_3's Avatar
Most dealerships will give you the carfax before you buy. But where did they get the truck from? The truck came from somewhere and more than likely has no problems. They can not by law tell you who owned it or where is has been due to privacy laws. I bought a "New" truck with 38 miles on it and found out a month later it was painted. Not just a small spot, the whole second door and part of the bed. They did not feel the need to disclose this until they had a lawsuit and were required to tell me where the work was done. It was done on a fly by night shop so I could not easily find it. Thus they did not have records of the repair and it would never be disclosed even after the lawsuit that I won.
