Old 09-23-2005, 12:13 PM
95fire 95fire is offline
95 firebird 3.4 hard to start
I have a 95 firebird that is hard to start hot or cold. I have changed the fuel pressure regulator with no change in condition. The car runs fine after getting started, but the fuel mileage seems to be getting worse. Any help would be appreciated.
Old 09-23-2005, 10:48 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Re: 95 firebird 3.4 hard to start
Only thing i can think of that would give you problems starting cold or hot would be a problem in the fuel lines.
1) You may have clogged injectors
~ Suggest running some fuel system treatment, but depending if the vehicle has high mileage, then I'd suggest to just replacie the injectors with new ones. It would be better in the long run.
2) You may have a clogged fuel filter
~Suggest replacing this.
3) Your fuel pump could possibly be on it's way out.
~ Suggest checking into the other the two things first. A bad fuel pump may be the case, but the odds are against it.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
