Old 09-23-2005, 08:13 AM
sumunabeech sumunabeech is offline
Won't go into gear
I just got an '86 Cherokee, 2.8L. Problem is, it won't go into first or second gear. My first instinct was engine mounts, but they seem to be okay. Operative words being 'seem to'.
I need to bleed the clutch also. I doubt that would be the reason. Any ideas?
Old 09-24-2005, 11:48 PM
vamc's Avatar
vamc vamc is offline
Re: Won't go into gear
A sencer possably that maybe went bad that is on your clutchplate. it could be locking you out, but thats just a long shot.
Old 09-25-2005, 07:21 PM
hiduke89's Avatar
hiduke89 hiduke89 is offline
Send a message via MSN to hiduke89
IM not exactly sure but my 89 wouldn't shift up until it got close to 5000 rpms's i put a new throttle poisition snsor in and it works like a charm now...u might want to check that out...refer to ur manual for instructions to check it.
89' Jeep Cherokee 4x4...(A.K.A.-Daisy)
4.0L Inline 6
4" lift 32"tires
Old 09-26-2005, 08:44 AM
Re: Re: Won't go into gear
I should have clarified that it is a manual tranny. I'm gonna try a new slave cylinder and make sure the system is bled. Then on to bigger stuff.
Old 09-26-2005, 08:51 AM
Saudade's Avatar
Saudade Saudade is offline
If you have air in your clutch system, this could prevent the clutch from disengaging and could certainly be the cause of your shifting problem.
Try, with engine off, shifting while rolling the jeep forward slowly. If it goes into gear, then it is most likely a clutch problem. Bleed the the clutch and check for leaks.
Old 09-26-2005, 01:48 PM
vamc's Avatar
Sounds good
