Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 09-22-2005, 09:49 PM
nealuss nealuss is offline
Send a message via AIM to nealuss Send a message via Yahoo to nealuss
running rough through rpm range
my buddy has an 87 300 Z and the rpm's want to jump around when he accelerates, it sucks gas badly, and on cold mornings it idles rough when he starts it and then it dies. any ideas?
Old 09-22-2005, 09:51 PM
Re: running rough through rpm range
i forgot to mention; it is a 3.0 V6
Old 09-22-2005, 10:12 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
uh yeah... they only came in 3.0 v6's for 12 years... anyway... by 'jump around' you mean rev up higher than it should be when he accelerates? could be a slipping clutch... put it into 4th gear where it's at 2k rpm and floor it... if the rpm's go up without accelerating, his cluch is on its way out/dead.... the bad gas mileage could be a number of things... has he done a tune up lately? (air filter, fuel filter, plugs, injector cleaner) that could be the cause of the rough idle/dying when it's cold... little more detail would be helpful
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 09-22-2005, 11:10 PM
freakonaleash1187's Avatar
freakonaleash1187 freakonaleash1187 is offline
Send a message via AIM to freakonaleash1187 Send a message via MSN to freakonaleash1187
the bad gas mileage and rough idle is most likley due to plugs and filters, replace all those and that should help. please explain the first problem better.
ZedEx Crew Member #2
Old 09-24-2005, 04:43 PM
the fuel filter; injectors, plugs, air filter, oil & filter and all has been changed. if i remember correctly he said that it kind of stumbles as the rpm's get higher and the way he described it is that it kind of skips to higher rpm's. It's an automatic so the clutch problem is out of the question, and he said he's had the transmission checked out, but he said no shops will work on these cars so he couldn't get anything else diagnosed. Thats about all i know to tell you. I know it could be one of about a million things with these cars; but i appreciate any input.
