Old 09-22-2005, 07:48 PM
hiduke89's Avatar
hiduke89 hiduke89 is offline
Send a message via MSN to hiduke89
suspension spacers
Can you buy spring spacers for an cherokee and if so where?
i kkno it isn't the right thing to do but im short on cash and need at least one more inch lift for my tires.
89' Jeep Cherokee 4x4...(A.K.A.-Daisy)
4.0L Inline 6
4" lift 32"tires
Old 09-23-2005, 01:37 PM
runuover runuover is offline
Re: suspension spacers
yes you can get them just about anywhere.i have 3 inches total of spacers all together i have 10 inches of lift and i never had any problems with them. its better to have bigger springs then spacers. but you will come out cheaper with the spacers.
Old 09-24-2005, 11:24 AM
hiduke89's Avatar
I have an 89 XJ i know i can use spacers for the front but what would i use to lift the rear?
4.0L Inline 6
4" lift 32"tires
Old 09-24-2005, 11:41 AM
hiduke89's Avatar
ok sorry but disregard that last post. my new question is if i get a 2" front lift how much would i need in the rear?...sorry don't kno much about suspension
4.0L Inline 6
4" lift 32"tires
Old 09-25-2005, 05:43 PM
lightningflash12 lightningflash12 is offline
Leaf Blocks
Blocks are an option but be careful because when I put some under my 96 Cherokee it made the rear sway bar mount rub the right rear tire. If you have aftermarket off-set rims then it's not a problem but if you don't then try to find an add-a-leaf or a shackle but go a touch less than the front to make it look right. If you have a 2" lift in the front you will only want a 1.5 to 1.75" lift in the rear. You can find most of these parts on ebay or get a hold of the guys at Roughcountry or Rubicon Express.
Also if you do add a lift be sure to have the foresight to maybe put in shims under the rear end and maybe even a transfer case drop to keep your driveline in lin to prevent added vibration. Again do a search on ebay or talk to the guys at Rubiconexpress, they were very helpful as to what the appropriate degree shim was for how many inches I lifted mine.
