Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 09-22-2005, 03:34 PM
jtaz33 jtaz33 is offline
dakota takes off w/o me
got a wierd problem. when i'm driving my truck (97 dakota 4cyl.) it accelerates on its own. when i give it some gas it keeps accelerating even when i remove my foot. like cruise control, except i don't have cruise control. i have to engage the clutch to get it back to idle, when i do it revs like i punched the throttle then goes to idle. it doesn't happen in neutral, just when i'm in gear driving, and i only need to give it a little gas for it to take off on its own. awhile back i had a low idle so i adjusted the pin under the throttle up a little and all was good. i also checked the voltage at the tps and it looked good. i got a code 55 from the dash, but after checking the tps i only get a 12 code. my hayes book doesnt say what code 55 is. i think i hear a hissing but i'm not sure. any help would be greatly appreciated.
Old 09-22-2005, 08:11 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: dakota takes off w/o me
12 is battery recently disconnected.
55 is end of codes.
My Mopars
Old 09-22-2005, 08:54 PM
thanx
Old 09-22-2005, 09:50 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
what your describing sounds like a vacuum leak.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 09-28-2005, 04:30 PM
for anyone interested, the problem turned out to be a combo of a bad iac motor and loose bolts on the intake manifold. apparently when i gave it gas, in gear only, the loose manifold open up a vacuum leak, which the computer, iac and tps compensated for, but when the iac motor blew the computer and tps couldnt compensate anymore. fix=new iac motor and new seal and tightening of the intake manifold. fyi
