Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 09-22-2005, 01:19 PM
bjd088 bjd088 is offline
Exclamation Transfer Case Stuck In 4wd
Hey I need help quick! Right now my '87 pickup is in my work parking lot stuck in 4wd. I shifted into it just see if it still worked with winter coming up I wanted time to work on it before too late. Now the thing won't shift out of 4wd. Any ideas appreciated. By the way, I would drive it out but the gears in the transfer case are binding and it won't drive until I get get it out of 4wd.
Old 09-23-2005, 12:15 AM
ECVcrawltoy711 ECVcrawltoy711 is offline
Re: Transfer Case Stuck In 4wd
put some muscle into it and push it out
Drew
Old 09-24-2005, 01:13 AM
tried that, but thank you. Any other ideas?
Old 09-24-2005, 08:56 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
You have a chicken and egg problem. The binding is what is probably keeping you from getting it out of 4WD. Dump some sand immediately in front of (and as underneath as possible) one of the wheels or two and make it move onto the sand. The wheel should spin and release the binding. You should then be able to get it into 2WD.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 09-26-2005, 12:19 PM
Thank you, actually i started the engine and drove it about six feet to the back of a truck I was going to tow it with, and it popped right into 2wd. So yes, that's exactly the problem I had, Thanks for the advice.
Old 09-26-2005, 06:54 PM
Brian R.'s Avatar
Resident Chemist
You're welcome
