Old 09-22-2005, 12:49 PM
danstg danstg is offline
Question 94 Grand Caravan - A/C recharged..still not really cold?
I recently aquired a 94 grand caravan SE.....the A/C did not work at all on it, just blew hot air. I bought a refill can of R-134A with the leak sealer from Advance Auto.
I recharged the system per the directions......when I run the A/C now, it takes about 5 min on full blast to even remotely start feeling cool. Eventually, it does get to a point of mildly cool....however I want it to be ice cold like it was the day it rolled off the assembly line.
what can i do to accomplish this?
It's obvious the freon recharge helped....what else can I check now?
could a new compressor help?
is there filters that need changed?
sensors bad in A/C system?
any suggestions would be greatly appreciated....reply here or email me [email protected]
thanks guys!
Old 09-22-2005, 01:54 PM
Mbriggs Mbriggs is offline
You should probably get a A/C pressure gauge and check the system's charge level. One can may not be enough, but you don't want to overcharge. I got mine at VIP for around $8.
Old 09-22-2005, 09:56 PM
faulty585 faulty585 is offline
Send a message via MSN to faulty585
Re: 94 Grand Caravan - A/C recharged..still not really cold?
ok heres some reading for you http://www.allpar.com/forums/index.php?showtopic=20709 it definately will help you to resolve your problemif you read it
Old 09-23-2005, 11:39 PM
papi62596's Avatar
papi62596 papi62596 is offline
Send a message via AIM to papi62596 Send a message via Yahoo to papi62596
I agree you should have the pressure checked. If your freon is low then that could be your problem. Buy one of the re-fill cans that come with the pressure gauge on it. hey usually run about $10.00.
