Go Back   Automotive Forums Car Chat > Nissan > Murano | FX45
Old 09-22-2005, 10:40 AM
acar acar is offline
fx35 Need Programming Instructions- keyless remote
Hi,
Does anyone know how to program the keyless remote for fx35.
It's 2005. and I do not have owner's manuel for my car..
Thank you..
Old 09-23-2005, 01:01 AM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Re: fx35 Need Programming Instructions- keyless remote
FX35:
Instructions:
1) New ID code has to be manually entered whenever replacing remote control or LCU 05, or adding additional remote control(s). To enter ID code, perform
steps 2) and 3).
2)Close and lock all doors. Erase original ID code(s) by inserting and removing key from ignition switch more than 6 times within 10 seconds. Hazard warning lights should flash twice.
3) Turn ignition switch to ACC position. Push lock button on new remote control once. Hazard warning lights should flash twice, indicating ID code for new remote control has been entered.
4) To enter additional remote control ID code(s), unlock driver's door and then lock it using door lock knob. Press lock button on new remote control once to enter ID code.
5) A maximum of 4 remote control ID codes can be entered. If same ID code is entered more than once, the entry is ignored even through hazard warning light will still flash. To exit progrmming (ID entry) mode, open driver's door.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
