Old 09-22-2005, 09:29 AM
GMC_Typhoon GMC_Typhoon is offline
Fuel pump issue?
On my '99 5.3, all of a sudden, the fuel pump stopped working. no sound when you turned the key, and the truck wouldn't fire. I pulled the bed, pulled the sending unit / pump assembly and dropped in a new one. It still will not do anything with the key on, or fire when you crank it over.
Stuff I've checked / verified.
1) The pump will move fuel from the tank to the fuel rail when "hotwired" using a spare battery; fuel comes out the schrader valve on the rail when opened.
2) The truck will not fire when the pump is hotwired and it is cranking over; getting fuel, but won't fire.
3) The fuel pump relay is good; switched it with the horn relay, and it works fine.
4) I cannot get 12V at the pump harness, and I believe I couldn't get 12V at the relay under the hood. Is there a fuse that feeds that relay?
When I pulled the bed, there is a block at the rear of the bed where 4 wiring plugs hook to. Does that need to be plugged back in for some reason?
I have checked the majority of the fuses; everything associated with ignition, etc. and they are all good. I cannot figure out why A) the fuel pump won't get 12V, and B) when you hotwire the pump to deliver fuel, why it won't fire.
Does anyone have a .pdf of the wiring diagram for a '99 X-cab Z-71, 4x4 5.3? Thanks.....
Old 09-22-2005, 11:19 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Fuel pump issue?
Check the ECM B fuse.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 09-25-2005, 12:18 PM
kev23 kev23 is offline
Re: Re: Fuel pump issue?
My Brother in Law had same thing on his truck a week ago. Turned out to be a blown VCM/PCM fuse in the box under the hood. Good Luck.
