Old 09-22-2005, 08:38 AM
SComp23 SComp23 is offline
Tune-Up Time!
I bought my truck used at about 52,000 miles, it now has about 73,000. I am not too sure about the prior history, so I decided I would go ahead and do a tune up after noticing pretty poor fuel mileage. I am definately doing cap, rotor, plugs, I have a K&N and I just cleaned that, I just got a fuel filter 2,000 miles ago. What else should I get? Wires? O2 sensors? I will definately use the Marvel Mystery oil like BlazerLT suggested, I used Seafoam last time, but that was almost a year ago! Thanks for your help guys!
Old 09-22-2005, 01:30 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Re: Tune-Up Time!
PCV Valve, and check your wires for corrosion when you swap the cap.
Old 09-22-2005, 02:33 PM
Re: Tune-Up Time!
I am away at school right now, and I don't have the time/space to do this myself. How much, a conservative estimate, should this all run me?
Old 09-22-2005, 05:38 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Tune-Up Time!
US$100 or less.
Do it in the parking lot.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 09-22-2005, 05:50 PM
Big Tall Dumb Ass
Re: Re: Tune-Up Time!
If you can't do the work yourself, you can expect to pay $200+ at a garage.
Old 09-22-2005, 06:15 PM
Re: Tune-Up Time!
I seriously think I am only getting like 225 miles to the tank, maybe a bit more, do you think just a tune up will help this average out, or does it appear to be something more serious. Also, how are Magnaflow mufflers, I am tired of running a straight pipe because it is so damn loud for one and for two I have no torque.
Old 09-22-2005, 06:23 PM
BlazerLT's Avatar
AF -Advisor
Re: Tune-Up Time!
do the cap rotor and plugs first before anything.
use the proper AC delco Platinum plugs gapped properly.
Old 09-22-2005, 06:25 PM
Re: Tune-Up Time!
Could I really be losing that much mileage because of just that?
Old 09-22-2005, 06:27 PM
BlazerLT's Avatar
AF -Advisor
Oh for sure bro.
Old 09-22-2005, 07:10 PM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
I was getting about 175 miles to a full tank (18 gallon tank) told the car dealer I bought it used at something was wrong and they did a full tuneup plus replaced the spider and now for the past 55k miles I am getting anywhere from 300 to 350 to a full tank depending on how I am driving. and just about 225 when I am towing something heavy and using drive instead of over drive
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 09-22-2005, 07:16 PM
Re: Tune-Up Time!
Awesome, I am definately going to be getting a tune up, sounds like a good start, also, should I be replacing those O2 sensors, My truck has over 70k, and I am not sure if they have ever been replaced. Nevermind I just answered my own question of course I should! Any thoughts on a Magnaflow muffler?
Old 09-22-2005, 07:27 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Tune-Up Time!
Probably was dumping fuel at the CPI level. Glad you
got you baby better
Old 09-22-2005, 07:33 PM
jsgold jsgold is offline
Would get a fuel filter on it too, if you are not sure how old it is. Cheap insurance against a fuel pump failure. Should be replaced every 20K in my opinion. Also check the serpentine belt. Plan to get a transmission flush and filter too, sometime soon if you plan on keeping this for a long time. Get this done at a reputable transmission shop. Cost should be $120-$130 for a total flush and filter change. As your truck gets closer to 100K would get the fluids changed in differentials too, and radiator flush also(depending on whether you use green or orange fluid. Refer to your manual)
I used to be indecisive, now I am not so sure.
Old 09-22-2005, 07:57 PM
Re: Tune-Up Time!
I just did the differential maybe 4k miles ago, the gasket blew and I had to fix it. The fuel filter is 2k miles old I believe. How do you know if it is dumping fuel at the CPI level? Does that sound likely at 73k miles?
Old 09-22-2005, 08:19 PM
BlazerLT's Avatar
AF -Advisor
You don't have CPI so don't worry about it.
You have CSFI which is the newer system.
