Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 09-22-2005, 07:05 AM
SilverLS SilverLS is offline
Recommend a spot for a subwoofer please.
I'm having a "Bazooka" tube style subwoofer installed in my 99 Rodeo today to give my stereo a much needed kick in the pants. It will be mounted in the cargo area behind the rear seat.
Can someone recommend the best way to mount this thing? Should it be put in laterally right up against the back of the seat? Should I put have it put in longitudinally maybe towards the wheel wells? Would the sound be affected one way or the other.
I want a spot that sounds good but won't be in the way (and have to be removed) every time I need to haul something with the back seat folded down.
Thanks. If I can figure this out I'll include a photo of the speaker.
Old 09-22-2005, 03:29 PM
directory's Avatar
directory directory is offline
Re: Recommend a spot for a subwoofer please.
good luck with that.
it will always be in the way, unless you try mounting it to the tailgate.
i'm in the process of designing a box that fits on the right side (passenger) cargo "pod" in a 99 passport, with minimal intrusion. only works with small box subs, but at lest it minght work. desing is a hassle. cardboard and duct tape make up most of the process. then it's a fiber glass issue. i just wish i had the ability to get the box covered in the same plastic that makes up the interior. looks like vinyl will be the best idea for that part.
i'll post photos once i get it to where i'm not embarrassed of it.
if anyone has any better ideas, let me know.
my idea of this came from a post found in the forums that pointed to an ebay auction of a guy who made something like it.
99 passport 3.2L v6 DOHC auto-trans 4x4 modified IFS 10 bolt front/ dana 44 4.10 rear
SKYWARN
we be clubbin'
--B
Old 09-22-2005, 03:31 PM
directory's Avatar
you could try mounting the sub on the wheel well. this way it dosn't use up much space and is off the floor.
some good straps for this can be found at a hardware store or car parts store. good luck
SKYWARN
we be clubbin'
--B
Old 09-22-2005, 03:57 PM
rodeo02 rodeo02 is offline
A place for a subwoofer? Right in the flippin' garbage!
Nah, j/kidding. Guess I'm too old and cranky. Our stock changer/cassette sounds great to me!
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 09-22-2005, 04:07 PM
amigo-2k amigo-2k is offline
Isuzu Guy
I was going to say tailgate too.
IsUzu makes an oem sub that fits in the cargo bay on the side. It is 370 bucks.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 09-22-2005, 05:01 PM
directory's Avatar
Re: Re: Recommend a spot for a subwoofer please.
WHAT!?!
SKYWARN
we be clubbin'
--B
Old 09-22-2005, 05:13 PM
Canucklehead Canucklehead is offline
Send a message via MSN to Canucklehead
Re: Re: Re: Recommend a spot for a subwoofer please.
Originally Posted by directory
WHAT!?!
He said, "Isuzu makes an oem sub that fits in the cargo bay on the side. It is 370 bucks."
2000 VW New Beetle TDI
2007 Honda CR-V
Old 09-22-2005, 09:21 PM
rodeovyn's Avatar
rodeovyn rodeovyn is offline
I have a '99 LSE Rodeo. I had an amp and subwoofer put in by Circuit City in 2000. Its pretty big, takes up about a third of the cargo area, but its not bolted in, I take it out as needed. Being single it never a problem space wise when I travel and greatly improved the sound quality.
You're right about one thing, the sound system definately needs a boost.
Old 09-22-2005, 11:00 PM
megavolt121 megavolt121 is offline
I just built a fiberglass subbox that's contored to the left side of the trunk. Its 14" tall, 6" wide and about 24" long. When i clean out my trunk, I'll take pics and post it.
Old 09-23-2005, 06:34 AM
Thanks for the tips. They wound up mounting it up against the driver side wheel well. Yes, it's bulky and in the way, but it is very easy to remove if the cargo space is needed.
Most importantly, it sounds REALLY good! I highly recommend installing one of these (or any other sub) if you are not happy with the sound of your current system. The difference is amazing. Now I turn the bass all the way down and run it exclusively through the sub. With the decreased low range work, the 4 speakers sound much better. Now I can play something loud with no distortion at all. And the bazooka sub has a dial to increase or decrease the bass independent of the radio. At 36 I'm a bit old for the window rattling bass, so I just turn it up just enough to add some nice low range response. Really, I'm shocked at how much better the system sounds now.
I wish I had heard about that Isuzu sub first though. That looks terrific. I had no idea they had one.
Anyhow, thanks again. I'll post a pic shortly.
Old 09-23-2005, 01:04 PM
directory's Avatar
Re: Re: Re: Re: Recommend a spot for a subwoofer please.
ok, i need part numbers and a place to buy it....
screw trying to make one.
SKYWARN
we be clubbin'
--B
Old 09-23-2005, 01:40 PM
You can get it here http://isuzupartspeople.com
Looks like you can only get it for 2002 and newer, but I don't know why since there is essentially no difference in 98 and newer Rodeos ????
Old 09-23-2005, 01:46 PM
Isuzu Guy
I think the 02-04 an a separate amp and wireharness for the sub.
-Ryan
Isuzu Moderator
Car Show Tips
Old 09-23-2005, 06:53 PM
Re: Re: Re: Re: Re: Recommend a spot for a subwoofer please.
You can get a better sounding sub for less if you make it. IT all depends on what you want. My sub( JL Audio 12W3v2) and fiberglass box cost around $300 and I have a sub that can be louder, but more importantly, has a better sound.
Old 09-23-2005, 11:07 PM
directory's Avatar
yeah, i guess you're right.
SKYWARN
we be clubbin'
--B
