Go Back   Automotive Forums Car Chat > Buick > Century
Old 09-22-2005, 12:41 AM
Daniel5306 Daniel5306 is offline
98 century, rear turn signal doesn't work and bulb good
98 century limited, rear turn signal doesn't work, but break light is good, I replace the bulb with a new one, the same problem. The auto repair agents said it was a bad turn signal switch problem, need more than 500 bulks. Is there other possibility for this problem? Thanks
Old 09-22-2005, 07:17 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 98 century, rear turn signal doesn't work and bulb good
Just to make sure you might consider checking the lamp socket and make sure no wires are broken plus whether the bulb is making proper contact.
The bad news is your mechanic is probably correct and the turn signal switch assembly has a bad contact afffecting only the respective rear turn signal.
The only other possibility is bad wiring but based on my GM service manual wiring diagram it's a straight wire from the output of the turn signal switch all the way to the rear of the car. The front signals have their own independent contacts and output from the turn signal switch. There are no fuses or fuseable links in the circuit. Good luck!
Timeslip 08/12/06
AF Community Guidelines
