Old 09-21-2005, 11:32 PM
Rottweiler28's Avatar
Rottweiler28 Rottweiler28 is offline
Code 26 HELP!!!
What do I have to do to get rid of this code? It started after I changed the fuel injectors. I have no idea on how to test them or the wiring going to/coming from them. The CEL is driving me insane.
Old 09-21-2005, 11:58 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: Code 26 HELP!!!
easiest way is to disconnect the battery. To test your injectors, you can put a screwdriver to your ear and put the screwdriver by an injector. If you feel it clicking and it speeds up w/ engine speed, your injectors are working electrically & mechanically.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 09-22-2005, 06:24 AM
faulty585 faulty585 is offline
Send a message via MSN to faulty585
Re: Code 26 HELP!!!
rottiiiiiiiiiiiiiiiii,
make sure all connections are secure to injectors remove battery cable for ten minutes restart and see if code reappears if it does,check for miss in engine usualy easier to find the miss then a problem injector?
Old 09-22-2005, 07:34 AM
Re: Re: Code 26 HELP!!!
I have already tried to clear the computer twice by dissconnecing the battery for ten minutes, didn't clear it.I did the front bank injectors with the screwfriver to ear trick and they all seemed to be firing ok. I will have to try to get to the back with it, snug spot in there.
I have already checked for compression and do have a low Cyl in the front, but I had this before I even changed the injectors, We have this tracked to possible valve issue as we did the wet test and the compression didn't return. Thanks for the replies.
