Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 09-21-2005, 11:03 PM
can'tgetright can'tgetright is offline
malibu overheating
I have a 2000 chevy malibu with 3.1 and it is overheating. I had a leak earlier and a mechanic said leak was at intake manifold. So replace intake manifold was leaking around sensor on manifold. Also change water pump, thermostat change temperature sensor on manifold and flush the radiator. The temperature guage still climbs up if I turn the defroster on and force the fan to run it does cool the engine, but i would like to get it to run normal. Any suggestions?????
Old 09-22-2005, 10:50 AM
bcopeland bcopeland is offline
Did you replace the manifold gasket yourself or have someone else do it? You need to make sure that you put good RTV on it.
Old 09-23-2005, 07:06 PM
bearcatdon bearcatdon is offline
Re: malibu overheating
What do you consider normal? The 3.1 runs high on the gauge. Normal highway temp is about 1/2 way and the fan doesn't kick in until it get at least to 3/4 or approx. 220 deg.
Old 09-24-2005, 02:14 PM
I won't say the 3.1 runs high. I will say that it is normal for the guage to rise above the midpoint and sometimes 2 - 3 clicks above and lower when you start running. That is quite normal. But when it rises above 3/4 point, then you may have a probklem. Don't rely on that Dexcool. I just flushed my 99 after 2 years of the stuff and prefer to so so often. But please change the Dexcool often. 5 years and you risk damage.
Old 10-01-2005, 03:38 PM
tcorbin8673 tcorbin8673 is offline
precisly the same . . .
My friend, you and I have precisly the same problem. A nearby mechanic wanted to swap the motor (!) for 1,500 smackers. I'm looking for a different mechanic. Did the head gasket change really help? Was it expensive?
Old 10-01-2005, 03:48 PM
Yu talking to me? I would say it helped, but the rough running I have been told is due to a slightly warped camshaft.
