Go Back   Automotive Forums Car Chat > Volkswagen > Rabbit
Old 09-21-2005, 05:56 PM
Kavioh Kavioh is offline
Fuel pump not kicking on
'84 volkswagen rabbit convertible
Fuel pump won't kick on
Tested with jumper cable
It works, kicks right on
Got a new relay
it won't work
traded in the new relay for another new one
still won't work
Any ideas at all?
please help
Old 09-22-2005, 07:52 PM
boschmann boschmann is offline
Re: Fuel pump not kicking on
Have you checked the fuse? #6
Old 09-23-2005, 04:53 PM
yea
we checked it, it's good
Old 09-23-2005, 10:03 PM
grandmastergd grandmastergd is offline
Re: yea
check to see if there is power at the pump. there is a ground wire that is under the carpet below the rear seat also check and make sure there is power and ground at the pump. If you bypass the relay you can get power at the pump with out cranking the engine. the relay gets a signal from the ignition system also. are you getting spark??
Old 10-12-2005, 06:46 PM
supervisor1886's Avatar
supervisor1886 supervisor1886 is offline
Banned
Maybe its not the pump. Anyway is it only one pump or two of them there? Because it might be the booster that gets gas to the main pump or some other ignition problem.
Old 10-12-2005, 06:50 PM
Banned
Check for fuel pressure anyway and the spark . Also the oil pressure sender can cause this on some cars dont know about yours. Doest the pump prime at all, do you hear it run- maybe some wire problems along the way since you tested the pump and it works. Maybe fuel pressure regulator?
