Old 09-21-2005, 04:28 PM
Tommyjohn Tommyjohn is offline
Exclamation Unknown Electrical problem.....couldnt be figured out by 2 mechanics
Hi my girlfriends father has a 1993 Pontiac Grand Am.
There is an electrical problem which cause the car to stall when the brake light switch is pressed.......and also when car is turned on the fuel gauge goes tops out(goes past full) but when you turn off the rear defogger it returns to normal. This problem has already cost him 400 dollars with no success. If ANYONE can help me out with this problem please send an email to [email protected].
I will respond in forum and through email.
Thanks a lot i hope i get some feedback from some good eletrical mechanics
Old 09-22-2005, 02:54 PM
grfnkl's Avatar
grfnkl grfnkl is offline
Send a message via AIM to grfnkl
I would start off by having the grounds checked as well as the battery. It sounds as if there is some type of short that is causing these problems, more then likely caused by the same problem... There may be a control module starting to go out as well.... Good luck
Old 09-24-2005, 04:56 PM
Re: Unknown Electrical problem.....couldnt be figured out by 2 mechanics
also a new problem ahs arised....when we disconnect the rear defogger the fuel gage is fine......but when we disconnect the brake light switch and go to plug it back in, the car stalls....when we put the right blinker on the right side door keeps locking it self over and over in sync with the blinker......anymore help guys????
