Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 09-21-2005, 03:12 PM
97T-Bird- 97T-Bird- is offline
Send a message via AIM to 97T-Bird-
Angry Dying Out
I just recently put glasspacks on my 97 bird and i would have to say about a week and a half later it started dying out a lot...its not safe to drive it. I took to my uncle and he said it could be because my car has so many miles on it that the oxygen sensors cant handle it... yet at the same time my fuel pump is pumping at 29 psi....and my check engine light isnt on or anything but it still dies. just wondering if anybody has any ideas of what the problem is thanks
Old 09-21-2005, 04:30 PM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
Re: Dying Out
New mufflers have nothing to do with it. Even though your CEL is not on, pull the codes.
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 09-21-2005, 09:46 PM
coondawg6 coondawg6 is offline
i thought we said car should have 40 psi in previous post for this car???????
DONT EVER LEAVE WELL ENUFF ALONE , ITS BORING.
Old 09-21-2005, 11:17 PM
Re: Dying Out
Maybe he needed a third or fourth opinion...
Old 09-22-2005, 02:24 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: Dying Out
If all you have is 29 PSI at the rail, I'd be willing to bet that the fuel pressure regulator has failed, thus not allowing it to hold the 40 or so psi that it needs. The exact same thing happened to me on my old '85 Thunderbird, kept dying out on me until I replaced the fuel pressure regulator.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 09-22-2005, 08:10 AM
97Bird's Avatar
97Bird 97Bird is offline
Re: Dying Out
flewthecoupe- The problem is everyone has the same opinion! Maybe he should start a third or fourth thread!
Old 09-22-2005, 08:26 PM
like i said in last thread that was started he could unhook the vacuum line from the regulator and the pressure should jump up if the regulator is working if the pressure jumps up but is still low reading the lines are restricted(as in kinked line or clogged filter) or the pump is bad.. if unhooking vacuum line and pressure does not change or fuel is leaking at vacuum port the regulator is bad(btw a bad fuel regulaotr can,but not always, set a code and turn on mil
Old 09-27-2005, 12:22 PM
97Bird's Avatar
Re: Dying Out
I forgot to mention that you have a very unique user name-NOT!
The Original 97Bird
Old 09-29-2005, 12:46 PM
'94F-150 '94F-150 is offline
Re: Dying Out
If you removed you catalytic converters or your O2 sensor that could be what it is. Starting in '95 all vehicles in the U.S. had to begin to actually use the O2 sensors to make them more efficient and not put out so much "deadly" exhaust fumes that were bad for the enviroment. Anyways, starting in '95 the O2 sensors really told the engine what the fuel to air ratio should be. If you remove the O2 sensors or the catalytic converters the engine will go crazy. That may be the problem. You should probably take it to a dealership and have them look at it.
Old 09-29-2005, 10:42 PM
Thanks for the help but it was actually the crank sensor cuz the people who put a new one in tied the wires to the wrong place and it was all messed up...but thanks and bird u know u like it
