Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 09-21-2005, 02:02 PM
draleigh53 draleigh53 is offline
2003 Jeep Grand Cherokee Radiator Cooling Fan Relay sensor Locations
Hi I'm New
I'm trying solve a radiator cooling fan problem.
my car over heats because the fan doesn't come on.
some say it is either the relay or sensor??
i have decide it's not the fan motor ,cause did a by pass and fan ran fine. i'm not gifted when it comes to working on cars, but thought if i could locate these items,maybe the would be way to test and find out which one is problem. if someone would please advise
i would appreciate the help.
thanks draleigh53
Reliv Saves Lives
Old 09-21-2005, 02:21 PM
Dale Aeppli Dale Aeppli is offline
Re: 2003 Jeep Grand Cherokee Radiator Cooling Fan Relay sensor Locations
Originally Posted by draleigh53
Hi I'm New
thanks draleigh53
Reliv Saves Lives
the sensor is located on the passengers side behind the headlight and bumper. you have to remove headlight assembly to get to fan relay
it's really hard to see so use good light it' just a black box about 1 inch square. Dale
Old 09-22-2005, 12:12 PM
Hi Dale
Thanks For Your Quick Reply .
Do You Know If This Is Usually The Problem??
Is There A Relay I Need To Look For And Check ??
Again Thanks So Much
Draleigh53
Old 09-22-2005, 01:11 PM
Re: radiator cooling fan problem
Hi Dale
Draleigh53
usually is the relay they get dirt and water causing them to short out ask for a fan relay for the year of you jeep. dale
Old 09-26-2005, 12:59 PM
Re: Re: radiator cooling fan problem
HI DALE
AGAIN I SAY THANKS SO MUCH.
DRALEIGH53
WWW.RELIVCHANGESLIVES.COM
