Old 09-21-2005, 12:09 PM
fishenguy_61 fishenguy_61 is offline
no blower motor 97 T&C
Wife calls and tells me no speeds. I checked the fuses and seems ok. We had issues with medium high but now nothing works, there was no noise to indicate bearing failure. Any ideas?
Old 09-21-2005, 02:49 PM
faulty585 faulty585 is offline
Send a message via MSN to faulty585
Re: no blower motor 97 T&C
if it was growling before probably motor but medium high problems sound like resistor
Old 09-21-2005, 03:13 PM
Rottweiler28's Avatar
Rottweiler28 Rottweiler28 is offline
Could be bad connection to the blower motor or the motor just went south, I have not tackled blower motors on these vans YET..lol. But when I checked them on my other cars I just tested them right at the motor to ensure power WAS getting there with multi meters. If so then I would say the motors gone. But I always used a direct power on my blowers just to test, I would dissconnect the factory power connection then run a positive to the power prong on the motor, then ground out and it should run if its working. Now as I said I have not did anything on the vans yet so make sure you can before trying this, but I cannot see why not. If it still doesn't work that way, it's gone to a better place.
Old 09-22-2005, 07:34 AM
Re: Re: no blower motor 97 T&C
you may want to read these forums http://www.allpar.com/forums/index.p...opic=43045&hl=
Old 09-22-2005, 01:24 PM
Thanks for the help.. i tried hooking up voltage and no go.. i banged on the blower hosing and it took off. looks like I get to change the blower
Old 10-24-2005, 09:39 PM
timd timd is offline
blower replacement
Hey fishenguy_61, did you replace the blower motor? How hard a job is it? My blower is intermittant. Not sure if its the motor or wiring but curious on the complexity of replacing the blower motor. Thanks in advance for a reply.
Old 12-12-2005, 07:44 AM
HeadlessHorseman's Avatar
HeadlessHorseman HeadlessHorseman is offline
Send a message via AIM to HeadlessHorseman
Re: blower replacement
If it's growling, it is the Blower Motor RELAY and possibly the Blower Moter. Here is everything you need to know, including part numbers and where to get them...
http://www.automotiveforums.com/vbulletin/t340871.html
