Old 09-21-2005, 12:07 PM
Dudge Dudge is offline
Headlight Trouble
I recently purchased a Dodge 2002 Grande Caravan and since I purchased it the headlamps have been nothing but trouble.
What happens is, the passenger front running light will be on, then when I go to dims, the driver light will come on and the passager off, then when I go to brights the passanger will come back on, but the drivers will go back off. Basically I am always driving with one light off and one on all the time.
Now I have taken this in and so far the Front Control Module (FCM) was replaced and this fixed the problem for a about two weeks, then the lights started acting up again. So I took it back in and they said they replaced the bulbs etc but this did not fix the problem either... Then I took it back in and they said I had a loose connection with the wires from the FCM and dirty sensors with the daytime running lights. This also worked for about two weeks but the lights are again acting up same as before, and I'm taking it back in tomarrow.
So is there anyone out there that has experienced this before and had it fixed once and for all?? Anybody that could shed some light on the problem and give me a clue where to suggest the mechanic go to fix the problem?
One more thing-- All four times I have taken the van into a certified service outlet at a Dodge dealership so the "experts" have been working on it the problem the entire time but can't seem to solve it---
Any ideas??
Thanks,
C
Old 09-22-2005, 07:16 AM
faulty585 faulty585 is offline
Send a message via MSN to faulty585
Re: Headlight Trouble
may or may not help but have they checked the grounds to headlites?sounds as though maybe module burnt out due to weak or bad grounds.just a thought!
Old 10-14-2005, 05:35 PM
Dwyatt Dwyatt is offline
I am having the same problem with my 02 Caravan. Low beam on passenger side, nothing on driver side. Hi beam on drive side nothing on passenger side. Driving light on passenger side, nothing on driver side. I have check the lamps both are ok.I check the voltage on each side and the voltages do not match. Does anyone have a fix for this problem?
Old 10-15-2005, 08:18 AM
B33p3r B33p3r is offline
I've seen this problem a few times in here but never saw anyone post the fix. You said the voltages aren't the same. What were they and on what side? And does everyone have the daytime running lights?
Old 10-15-2005, 08:04 PM
eldiablo1100's Avatar
eldiablo1100 eldiablo1100 is offline
Send a message via AIM to eldiablo1100
have someone check the wiring. they're double filament bulbs so there should be 2 sets of wires going to each bulb, could be someone screwed up the wiring when they installed it
Old 10-15-2005, 09:22 PM
The voltage on the right(passenger) was about 2.5 VDC, on the left,(driver) it was about 8 VDC.
Old 10-17-2005, 09:10 AM
Nothing scientific about this response, but the front control module has 4 12 volt inputs from the battery. At the front control module check pins 1,2,9,38 to see if they all have 12 volts to ground.
Old 10-17-2005, 01:17 PM
neon_rt's Avatar
neon_rt neon_rt is offline
I had a similar problem with a '00 GC.
Turned out that the socket had partially melted and the ground for the bulb no longer made contact. I ended up replacing the socket. Now.. the reason the socket melted...After-market non-DOT approved blue lamps I bought off of E-Bay.
Old 10-21-2005, 08:46 PM
Re: Re: Headlight Trouble
I have check all of the connections, all are clean and appear to be in good shape.
Old 10-25-2005, 08:23 AM
My only suggestion at this point is to get a reliable electrical diagram and verify each wire from point a to point b all the way through the lighting circuit. Alldata.com comes to mind but will cost you $25.00
I have diagrams for a 2001 GC if you would like them. I don't know if they will be the same.
Old 07-26-2006, 02:55 PM
xrayeyes2u xrayeyes2u is offline
I am having the same problem w/ my 01 Dodge Grand Caravan...have read to replace battery - which we did...only fixed problem for a day or 2. If anyone can send me the electrical diagram it would be much appreciated. The dealer chuckled and said "it could be wiring" -- like "GOOD LUCK!"
Thanks!
