Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 09-21-2005, 12:32 PM
renechua renechua is offline
Smile Water Pump Installation
Hi. Thinking of replacing my Venture 98's water pump. What do I have to go through replacing it? Thanks.
Old 09-21-2005, 09:55 PM
DRW1000 DRW1000 is offline
Re: Water Pump Installation
I don't know the differences between a 98 and a 99 but on my 99 it was the easiest water pump replacement I ever did (I have only done 3 mind you).
Assuming the 98 is the same:
The pump is simply the plate that includes the impeller and pulley. You need to the following:
Drain coolant
remove serpentine belt
remove the five bolts
remove pump
Clean mating surface
Install gasket and dressing on pump surface (note there is only one correct orientaion - holes are not all equidistant)
install pump and bolts
re-install belt
fill coolant.
I may have removed some stuff near the battery for better access - I can't remember
Old 09-21-2005, 11:24 PM
cdru's Avatar
cdru cdru is offline
IIRC, on my 98 I had to remove the pully first to gain access to the bolts holding the waterpump on. But the above instructions is about it.
Vinyl adds horsepower, right?
