Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 09-21-2005, 11:27 AM
DAVU DAVU is offline
Angry 1994 Dodge Intrepid Blows Radiators
I have a 1994 Dodger Intreprid with the 3.5 ltr engine that for a mysterious reason overheats without warning, although ususally after sitting in traffic. The dealer has not been able to replicate the problem. I have already blown two radiators. The thermostat is new and I let the air out of the valve when I installed the radiators. The car has now 150,000 miles on it. Is there another device that is the culprit? Anyone with a solution? Thanks in advance.
Old 09-21-2005, 09:44 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: 1994 Dodge Intrepid Blows Radiators
your cooling fans are not turning on, this is a common problem on these cars. Check your fan relay which is in your underhood fuse box; switch it out w/ another relay and see if it kicks on.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 10-04-2005, 05:34 PM
You may be right on this. I changed out the high and low temp relays (I noticed that they are all the same regardless of the application) and observed the fans going on. They seem to shut off even though the engine is still hot (according to the gauge). Should I also replace the temp sensor before I buy another radiator?
You are the first person who has ever provided sound Dodge advice. Thank you much.
