Go Back   Automotive Forums Car Chat > Ford > Probe
Old 09-21-2005, 06:56 AM
91esinga 91esinga is offline
Timing belt slipped? Does it hurt engine?
I guess I got a slipped timing belt, The timing marks are like at the top instead of facing each other in the middle. My question is, if the timing has slipped on a 1996 2.0 DOHC engine, does that cause the valves to hit the pistons and warp em? Thanks
Old 10-06-2005, 07:02 PM
Mazor Mazor is offline
Well it can, how did it slip that far, if it did slip that far, it could do it again causing your engine not to start, miss fire, back fire you name it
Old 10-21-2005, 06:10 PM
BCUZICN BCUZICN is offline
Send a message via AIM to BCUZICN
it should be ok, i believe the mazda engines in those years were designed with non interference pistons so it shouldnt cause damage, but i wouldnt drive it with the marks off like that, get it fixed and find out why they are moving before it gets fixed, could be bad bearings slowing down cam, ect.
Old 11-02-2005, 09:11 PM
a1waytrip a1waytrip is offline
Re: Timing belt slipped? Does it hurt engine?
2.0 dohc??? lol, if you've got the gt you have the 2.5 dohc, or if you have se you have 2.0 sohc. both should be ok if the timing belt breaks, being the 2.0 is a 4 cylender, and the 2.5 is a non-interference engine, so no worries about it screwing too much up if it goes... however, i would never drive my car if the timing belt slipped a tooth.. not a good idea, get it fixed asap, and replace the tensioner arm when you do it.
-Tom
Old 11-03-2005, 06:31 PM
shawnwilliams's Avatar
shawnwilliams shawnwilliams is offline
i now for sure you just have to get a new belt and re-timed and its fine, the gt and base models wont cause any damage dont to it.
93 FORD PROBE GT
JDM manifold ported match
65mm TB
Unorthodox Underdrive Pulley
Hotshot headers
3' Exhaust all the way
No cat
Cold air intake
K&N air filter
Short throw shifter
Eibach lowering springs
FX Design Body Kit
B&M Short Shifter
Stage 3 Clutch
MX-3 Flywheel
Performace Wires and Plugs
Synthetics
Performance Rad and fan
Mild Weight Reduction
Coming this week:
Performance Heads and Cams
3 angle head job
Why does everyone have to piss on Ford.
Old 12-05-2005, 08:09 PM
cberbes cberbes is offline
-Tom
Why are you laughing? The 2.0L 4-cyl IS a DOHC. One intake cam and one exhaust cam = Dual Over Head Cam.
To answer the question, if your car is obviously running crappy, then yes your belt most likely slipped a tooth or two. If it isn't running or starting, then it skipped a few teeth, or broke the belt. The 2.0L DOHC is not an interference engine, so a slipped or broken timing belt is NOT going to cause any valve or piston damage.
You can replace the belt yourself in your driveway, but expect to take a day of so to do it...depending on your experience. I would highly recommend lifting the engine out of the bay slightly. Lift up the front right corner of the car, use a block on the oil pan, lower the car so the pan rests firmly on the block. You can use a good floor jack to lower and raise the car, causing the engine to raise or lower in the engine bay. Obviously you need to remove the right upper mount to lift the engine, but doing so makes things VERY easy. I would also recommend getting a cam-stop tool that rests between the two cams, keeping them in place when you start putting on the new belt. Remove the upper and lower covers, crank pully, all belts, water pump pully, valve cover, and timing belt tensioner. You need to rotate the tensioner to remove the tensioner spring, then remove the belt. Be sure to line up the marks on the crank and oil pump, and the I and E marks on the cams. I did it on my mothers car Sat, but I didn't use the cam-stop and ended up putting it out of time. I redid it today and it only took under 3 hours from start to finish.
Good luck.
