Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 09-21-2005, 04:58 AM
Tom01Rodeo Tom01Rodeo is offline
What is your idle speed? '99-up
The idle on my '01 Rodeo seems a little high and was wondering what everyone elses is. Mine is around 900 out of gear and 850 in gear. My Silverado runs around 500-600. So far I've changed the intake gaskets, cleaned the egr/passage, and throttle plate. These models have the drive by wire system and I believe the idle speed is controlled by the pcm and the throttle position motor. I don't think theres a traditional idle speed motor or valve, is there?
Old 09-21-2005, 08:56 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: What is your idle speed? '99-up
I’m at about 720-750.
There was a recent post (here? Or on the planet or the wire) that the person sprayed out their idle control sensor and it helped to bring the idle down a bit.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 09-21-2005, 08:57 AM
Isuzu Guy
http://www.automotiveforums.com/vbul...d.php?t=460021
here is the trend
-Ryan
Isuzu Moderator
Car Show Tips
Isuzu Guy
thanks for the info/
I will put this in the FAQs
-Ryan
Isuzu Moderator
Car Show Tips
Old 09-21-2005, 09:20 AM
rodeo02 rodeo02 is offline
Somewhere between 700-800rpm idle speed is pretty normal for the 3.2L Tom01- keep in mind your silverado probably has a V8? A V8 will idle slower, have a lower max rpm, etc. I don't think the throttle by wire equipped 3.2L's (2000+) have an IAC valve. The TBW system actuates the throttle as needed when cold.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 09-21-2005, 03:56 PM
directory's Avatar
directory directory is offline
i'm running about 700-900 rpms.
that's, of course, after warm up. warming up i'm running about 1000 rpms--it seems (normal?)
99 passport 3.2L v6 DOHC auto-trans 4x4 modified IFS 10 bolt front/ dana 44 4.10 rear
SKYWARN
we be clubbin'
--B
Old 09-21-2005, 04:53 PM
I'll try to look for a idle control motor or valve. I've played around with them on other GM vehicles, so I know what to look for. Wondering if a temp sensor is going south, causing the engine to idle high. It seems like I'm always fighting the idle speed when I pull up to a stop-like it doesn't want to stop.
Old 09-21-2005, 09:52 PM
Tom, dont forget there is also an idle-up pressure switch on the power steering pump. Look for the single grey wire on the pump. Disconnect it to see if it idles down. The switch can get stuck. Disconnecting it will have no ill effect. It's not really needed.
G/luck
Joel
Old 09-22-2005, 08:16 AM
Really?? Never heard of such a thing. I'll check it out, thanks.
