Old 09-21-2005, 01:57 AM
1996EclipseRS 1996EclipseRS is offline
N/A 420A Performance Problems
I rebuilt the engine myself at 112,000 miles Auto.
Pulled the engine. Replaced all gaskets, water pump, main bearings, rod bearings, Crane valve springs, JE Forged 10.5 pistons with rings, Eagle rods, Crane Performance Cams, EBay header, EBay intake, EBay High flow cat, radiator, thermostat, timing belt, OEM coil pack/wires, torque converter, got the recall fixed. Everything else is stock.
Problem:
Car is slow as hell. I could swear its slower then a stock RS. Do I need
to reprogram the computer? Get a new one? That is an area I am not too familiar with. Or is it something else?
Help!!!!
Old 09-21-2005, 12:39 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: N/A 420A Performance Problems
your likely aren't flowing enough fuel and the spark isn't advanced enough for your new cams and compression ratio.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 09-21-2005, 09:45 PM
Re: Re: N/A 420A Performance Problems
So a better ignition coil / bigger injectors?
Any other suggestions??
Please I need help, trying to sell this car.
Old 09-22-2005, 10:01 AM
could I get some help?
Old 09-22-2005, 04:31 PM
drdisque's Avatar
you need an SAFC or similar to properly tune the fuel flow. Spark advance I believe has to be done through the ECU.
Dr. Disque -
Current cars:
2011 Mazda2 Touring
Past cars:
