| Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive. |
lowering a civic
ok, no one in the 6th gen forums knows jack about lowering a civic obviously, which i dont understand why... anyways, i heard that when you take the rear struts off of a civic, 92 or newer, that usually, u have to buy a new control arm, because somehow they mend themselves together and you have to torch them apart, which ruins the control arm? sound familar or just a garbage story... i just want to know what im getting into when i put these coilovers on, i just bought them because because my front coil spring are bad and i figured i would kill two birds with one stone, anyways, please let me know, thanks
Re: lowering a civic
What usually happens is lower control arm bolts seize into the bushings. New LCA's are not needed, it's just the quick & easy fix.
if you bought the cheap coil over sleeves, its not the best choice... but you already got them so oh well... yes the bolts DO get stuck in the bushing, in fact, thats why my car is parked... waiting for a slow family member to take my a arm and press a new bushing in it. i had to take a saws all and cut both sides of the bolt, then grind off the head of it just so i could get it off... it could have been like a 30 min job, but it turned out to be 2+ hours... + a couple days of waiting.... SUCKS!!!
95 Civic EX H&R sport springs KYB AGX Struts Energy Suspension Poly Bushings 15" black VSR's on nitto NT450 not-so extreme performance 205/50/15 CAI http://www.cardomain.com/ride/2489240/1 |
Re: Re: lowering a civic
so basicly, i should order the bushing and bolts before i decided to do this? and thats what i would need right, the LCA bushing/bolts?
Re: Re: Re: lowering a civic
It doesn't happen in every case but it is common. You can always return the parts if not needed. You will need rear LCA strut bushings & bolts. Don't be cheap with the bolt those are structural & support a lot of weight. If seen case where people use $0.20 bolts from the hardware store and wonder why they broke . . .common sense.
Re: Re: Re: Re: lowering a civic
yeah, ill def get the right parts from the parts store... just wanted to make sure which parts i was going to need... thanks guys
